Error Bridge drive fault and Trolley drive fault
Andyscarwash
Hey,
I was wondering if anyone has come across a bridge drive fault or a trolley drive fault on the pdq 360
Getting both errors show up.
Thanks
GPAW
Check your low voltage cord in your echain (system stop cord)
jb405
I am getting the the trolley error on mine too, as of last night. Did you ever find a solution?
GPAW
are you getting it intermittently or on a certain part of the wash? Where the trolley stops at the same spot, your wash abort report should be able to tell you this.
jb405
Take a look at your e-stop circuit. That seems to be what was causing our issues.
jb405
Ours was seemingly random. I took the estop buttons out of the circuit, and I have not had a problem since. I need to order the replacement switch.
