flojet vs procon pumps
coinman53
Pennsylvania
That's not how to do it. You could, theoretically, but it has no advantage over having a pump for each low pressure selection, and you would have really long changeover times. How is yours set up now?
A 1/3 HP motor is enough to max out the pressure of the pump I linked.
Since I have only two bays I would like to use one pump for each bay instead of presoak pump for two bays. the reason is I live right here and If I have trouble with a bay using presoak I can give money back give a free wash on other bay. So that would be my advantage to at least have one bay open.
Sure you could probably do that, it'd take some doing but it could be done, but it won't be cheap.
Then you might want to consider Flojet pumps with the quick-change mount instead. It takes me about 30 seconds to swap out a pump if it's not working. It takes me longer than that to open the changer to give a refund.
Like I said, you could do what you want with a Procon for each bay, but your customers won't like it, and you would still meed one dedicated for foam brush so you won't end up with fewer pumps.
Bud's
Procon 1/2" pumps are listed as 240 gph
Flojet G57 are listed as 5-7 gpm
Tip size 2506 being the restriction on the wand shows a flojet @80 psi would still be restricted down below 5-7 gpm.
I also installed the flojet on a separate wand with 4040 and it needs more volume even when testing one bay. So I put on two G57's and it didn't look good enough.
I have been wanting to switch to procon on its own gun 4040 tip, but they are listed smaller volume by over half when comparing to a G57.
It looks to me like I need more volume then what either of these are capable of?
What are you trying to do? Are you trying to get a good liquid-only pressure with a 4040 tip? The only time I've ever used or seen a 40 GPM rated tip in a self serve is on a foam gun, where most of what gets to the gun is foam. You should be able to run at least six bays at once with a G57 Flojet.
Bud's
Looking for the foam cannon type of foaming.
When I hook up the foam style gun with the 4040tip and a g57 I wasn't impressed and now I see people are using the procon that has even less gpm.
Apparently I have a bottle neck in my system holding the flojet back that's not the 4040 tip.
mjc3333
PA
Here's a pic of my coleman stand like Mep was referring to
What model Procon pump is in the picture? Do you set the pressure within the pump, or do you rely on the pressure regulator connected to the solenoid bank?
I'm not sure why they put a regulator on the solenoid stack when the pump's internal relief does a good job. When the one on the stack fails, I just remove it and adjust with the pump. Even with a regulator on the stack, the one on the pump is working to keep the pump from running at its max PSI, in fact I've made several service calls after someone changed their pump and, since they didn't know to reduce the pump pressure, it started blowing the fuse.
mjc3333
PA
Thanks. That model you gave me dosen't have a pressure regulator. Which model would have the regulator. I'm going to use it for foam brush. I dont need 100 to 200 psi. Maybe 50 or 60 psi.
It does have the regulator, they just use a stock photo of the model without for all the 1504 series pumps.
mjc3333
PA
Ok thanks. This pump model can be adjusted to 50 or 60 psi with the internal regulator?
Yes, but it won't go much lower. I recommend you take the cap off with the pump off, back the adjuster out until it's held in by at least a full thread, then turn it on and adjust it in/up until you reach the pressure you want. I've seen someone back it out too far and had all the valve parts shoot out the opening when they loosened the adjuster too far out.
mjc3333
PA
Got it.
If you're using 1/4" tubing to the bays, that will be your bottleneck, try using 3/8". You'll get the same flow at 8 times less pressure. Same as being able to get 8 times more flow at the same pressure. A flojet has more than enough volume, but the tubing has to be sized correctly out from the flojet or even a procon.
1carwash1
east japip
We just moved the TC & PS to dispense out of the Tri foam gun utilizing the existing 1/4 poly tubing. We used a flow jet g57 pump and the existing 5040 trifoam tips. Were are getting great coverage and lots of positive feedback. 2Biz, I don't understand how you came to the conclusion that "You'll get the same flow at 8 times less pressure" from the attached table?
