Foam brush heads
I am still waiting on the metal head Erie NOGshair brushes. I did get 4 more of the Nog hair brushes in from Kleenrite. 3 of the 4 had been used by someone who had stripped the threads and some of the bristles were smooshed so they had been used a while. KR said they must have come from the MFG. that way. Now all the hassle of sending them back etc.
OK, which one of you guys did that? :)
I've had manufacturers tell me they don't sell certain things through Kleen-Rite because of issues like that.
Reviving an old thread. Just bought 8 more of the "Nogs Hair" brushes since I had very good luck with the first ones I bought. Only issue I had with the original ones, when tapping out to 3/4" pipe threads, 2 of the heads cracked when inserting the 1/2" to 3/4" brass adapter. I guess going to the larger diameter threads made the wall thickness thin enough to crack under pressure. So I ordered the Acme thread to 1/2" brass adapter to try so I don't have to do any altering. For those of you that used this adapter, did you use any glue/epoxy? Or was the connection strong enough without using anything to bond the brass fitting to the plastic head?
For the ones that cracked, I tried using gorilla glue, but they wouldn't hold when tightening the 1/2" x 3/4" brass bushing. So I bought a Wavy Staple like wire plastic welder I'm going to try to see if that holds up. I'll let you know if it works...
Since this thread is already 2 years old, I'm guessing I get about a year out of the brushes! Just as good as the Erie ones for $60-$70
Foam Brush Adapter | Foamy Brush Adapter | Foam Brush Handle Converter | Erie Brush Accessories (kleen-ritecorp.com)
Synthetic Hogs Hair Foam Brush | Hog Hair Alternative | High Quality Foam Brushes | Kleen-Rite (kleen-ritecorp.com)
I tried one with the adapter. IIRC it was about half that price at the time, so I wasn't worried about making it a one-use item. I drilled a hole through the plastic and into the adaptor, tapped it, and used Loctite on the threads, then cut off the screw head. I didn't fully tap the adaptor so I could feel the screw tighten up before it went through.
Tried the nogs hair and it was OK. However, I get such long life out of my brush heads that I'm really not concerned about the cost. I could see them useful in an area where theft or abuse of brushes is a problem.
