Foam Brush Pump Replacement (Recommendations)
Officer
Shelbyville, KY
I need to replace my foam brush soap pump. Any recommendations on what to use or buy. Three bays. Currently using a myers pump with a low pressure switch on the side. Thank you in advance!
A good twin diaphragm pump. Flojet pumps aren't as good as they used to be but they're cheap and very easy to replace.
Are you talking about a Shallow well pump with a pressure switch and tank? I haven't seen one of those setups in over 25 years. Go on EBay and buy a Flojet G55 pump, it'll cost you about $30, I'd buy 2 of them. The G55 is the same pump as the G57 that Kleen-Rite sells. The only difference is the G55 uses stainless steel fittings, I've been using them for years. A word of caution, you HAVE to use a reinforced hose on the discharge of the pump, a Hydrominder suction hose won't work, it'll break/pop and you'll have a hell of a mess.
Officer
Shelbyville, KY
Yeah Randy, that's what it is with the shallow well myers pump. How difficult would it be to switch the pump system over to flojets?
Simple, you'll need an air line for the Flojet with a regulator to control its output pressure, a 1/2" hose with a foot valve from your mixed chemical to the pump and then straight out to the solenoids. It's good to have a controller and a solenoid to shut off air to the pump while it's not being used, but I've found it unnecessary as long as you have a good strainer on the inlet line.
Officer
Shelbyville, KY
Ok. Does the Flojet automatically mix air with the soap to make foam? Sorry for my ignorance. Just trying to understand how it will work.
It only pumps liquid but uses air to pump it instead of electric. The foam is formed by injecting air together with the liquid further down the line.
Has anyone used this pump for presoak or tire cleaner? (high PH)
It looks like the G55 is single-purpose for pumping soda syrup and only has Santoprene seals, so the G55 is not the same pump as the G57 Kleen-Rite sells. The pump body may be almost the same aside from the fittings.
I've used the Santoprene G57 on tire cleaner, trifoam wax and very high pH presoaks and get at least a year out of them vs at least 5 years for the Viton. The money math and reliability tells me to use Viton G57 where needed.
Officer
Shelbyville, KY
I will definitely go with the viton seals. Will one pump handle all three bays if all three bays are being used, or should I use two pumps? In any event, if I used two, how would I connect them together? Run the supply to inlet, then outlet to inlet on second pump and then outlet to the solenoids?
Lastly, what's the part number on Kleen-Rite? I see several variations of the G57 pump...
Sorry didn't mean to confuse you but was just curious if anyone had used the G55 on high PH. If you are just using it for foam brush soap you don't need the Viton because the soap is pretty neutral. I'm sure the one Randy suggested would work fine especially for less than half the cost of the G57 Santoprene from Kleen-Rite. One pump will handle three bays easily.
The internals of the G55 are the same as your standard G57 pump, Santoprene. We use a Procon pump for our Presoak and Tire cleaner and the G55 for foam brush. We've been using them for at least 4 or 5 years. They seem to last as long as a G57. Back before the G57 or G55 we used a 5100 Flojet that only put out about 2gpm, they worked OK.
One pump will easily handle 3 bays. I've used the G57 for presoak on a 6-bay wash, maximum pressure and no needle valves, and one can candle all six bays with no problem. If you needed two you could just tee them together, in fact they have a double volume pump which is just two pumps with a manifold/bracket.
https://www.kleen-ritecorp.com/p-3419-flojet-g57-dual-pump-10-gpm-12-viton.aspx
The standard Viton model:
https://www.kleen-ritecorp.com/p-2091-flojet-g57-air-pump-7-gpm-12-viton.aspx
Mep do you use the Viton pumps on the foaming brush?
I do, only because rather than keep two kinds of pumps on hand I keep two spare Viton so I can use them anywhere. The Viton won't last longer than Santoprene on foam brush.
Randy is right...The G55 is virtually the same as the G57. I got (4) G55's off Ebay for $25 each....I put one on my Washer Fluid Winterizing system about 4-5 years ago and it still works fine. The G55 puts out about 5 gpm….Do the math...It will keep up with a lot of bays of PS or FB soap....
I do, only because rather than keep two kinds of pumps on hand I keep two spare Viton so I can use them anywhere. .
I do the same. Between the SS and 4 tunnels probably have 60 in operation. I find best thing is to have a moisture trap with auto dump as close to the pumps as possible. Air heats up as compressed and and will cool as it moves down the line from the compressor. So, since warm air holds more moisture than cool moisture will condense as it cools. So, a trp near the compressors will not eliminate the condensed moisture further down the line.
