Foaming Brush
ecj326
Charlotte Mi
Would someone have a diagram of how the air and liquid lines are routed on a foaming brush system ? I cannot seem to get them to foam. It just runs out like water.
I have replaced the foam generators. Any advice would be appreciated.
Is your chemical strong enough? It might be too watered down to foam.
Damoni88
Lake charles la 70605
Also make sure you have more chemical than air. Are you using flo jets? Check chemical to make sure its not watered down. Do you hear your air?
What brand foam brush soap are you using? Are you using a Hydrominder to mix it, what color tip are you using? I run my air pressure at around 35 - 40 psi and the chemical at about 40 - 50 psi, I think I haven't had to mess with it in years.
Were they working good and then not? If so, I would make sure your water is not hard. That's usually the first thing that makes me notice when the water softener has stopped working.
Weak chemical is always the first suspect. Check your hydromider for adequate flow. They have an inlet screen that goes bad, and also the diaphragm inside goes bad periodically and must be replaced.
Roz
We usually increase the chemical to water mix above the ratio on the container by a few tips. Then the product line setting should be at least twice the air (on an AirLogic system)
