I have an automatic control that is supposed to switch from antifreeze soap to warm weather soap for the foamy brush when the outside temperature changes at a set temperature threshhold. I have two flojets - one for each of the two foamy soaps. The problem is that the flojets get hung up and the switchover from one soap (flojet pump) to the other soap (flojet pump) does not happen. As a result neither flojet pump works and thus no soap to the bays. Each time this happens I have to shut the air line down and then blled the flojet pumps to get the air to start pumping again. Any suggestions?
