Gasoline in the trunk !!!!!
Bud
NE Ohio
I have had the need in the past a few times to try and give advice to people that have spilled gasoline in a car. I really don't know where to send them. Now my neice has spilled a gallon in her trunk. Where should she go? A detailer, a car dealership etc. What is the best way to handel this type of spill.
Don't know for sure ,but I have heard that putting charcoal in a rag and place in trunk will absorb the gasoline and order?
I did this a few months ago. Someone suggested an ozone machine which i didn't have. I poured bucket after bucket of water on it and kept vacuming it out with a shop vac. I then poured a bunch of vinegar on it and vacumed out. It smelled like a oil and vinegar salad for a while but eventually got better.
I dealt with a gas oil mix spill in a Yukon which made it almost unbearable to drive. I had to steam clean it 3 or 4 times and then used my ozone machine for roughly 20 hours. Been perfect since.
I'm selling my ozone machine if you want to purchase it ;-)
A few years back we had Ozone machines, when working properly they sparked a wire grid to produce the ozone. If your ozone machine sparks it would be dangerous near gas fumes.
The biggest thing about any kind of petroleum product spill is the smell.
You have to remove anything that the gas had contact with, all carpeting, all plastic, spare tire, jack, etc.
The only thing left should be the unibody of the trunk itself.
DO NOT ever vacuum gasoline! Mop up as much as you can with rags and or paper towels and dispose of them properly.
Use a good quality degreaser on the entire trunk. If you can find the drain plug for rain water, most trunk's have some sort of drain, remove it. Now you can either pressure wash the trunk, or just flush out any remaining gas with a regular hose.
As far as the other items, especially the cloth, or fabric components, the best way to remove the gas is again with a good degreaser and a blast of hot soap from a SS car wash in the bay. You may have to do this many more times than just one time. Once you are satisfied that the gas is gone, wait until the item is totally dry and sniff it for any remaining fumes. If you still smell the gas repeat the whole process. If you don't get the smell out completely, and proceed to put the trunk mat / gas soaked items back in the trunk, the gas fumes will never go away.
We have done this many times at our detail shop and have found this to be the only sure fire way to guarantee the results.
seattleguy said:
By the time I was vacuming the gas was pretty well diluted.
You were very lucky. Gasoline doesn't "dilute" in water, and the flammable part isn't the liquid but the vapor.
1. Put on some rubber gloves.
2. Sop up the gas with some old bath towels.
3. Drape the towels over an old lawn chair or similar out of the way; over sand, if you can. The gas will evaporate in a day or so. Dispose of properly.
4. Pull the rubber plug in the trunk bottom.
5. Wash the metal.
6. Blow a fan at it.
7. Replace rubber plug.
