Get off stain from Tri-Foam?
I had a customer complain today that the tri-foam stained his white car. I have never had that complaint and told him there wasn't much I could do since he left and complained after 3 hours, but it made me wonder if there was a way to remove the stain if indeed it was from the Tri-Foam. I have been using Warsaw Tri-Foam at the same concentration for years now without a single complaint, so not sure if really did stain his car or not, but it would be good to know.
Thanks.
tdlconceptsllc
NC
Put straight preasoak on a rag and apply it will come right off I have done this years ago a old timer trick. When tri color foam first came out it stained a lot of things 20 years ago is what veteran operators have told me. I have had to do this years ago myself
Thanks for the tip. I'll try it if/when he contacts me again. I wasn't there and just spoke to him on the phone, but after saying he he was calling a lawyer he took a bunch of pictures of the wash then took off from what I was told.
I quit using Warsaw trifoam CCP for this very reason.
The sun will bleach the stains out after a couple of days.
tdlconceptsllc
NC
Older cars with a thin clear coat on the paint tend to absorb the stain more from what I have seen. True Polishes are not as strong of colors as clear coat foam I have found most manufactures make both but the polish will cost a little more and works better.
TheTallGuy
Lincoln, NE
I had the same issue with my tri-gloss. It was the blue color in my case and it was on white cars and light colored cars. The darker colored cars would not show it. I quit using the blue and only run red and yellow.
TheTallGuy
Lincoln, NE
It was the blue pigment in the product. I have a silver mini-van and you could faintly see the blue on it. Rinsing would not take it off. You would need to wipe it down to remove. I don’t have a tri-gloss anymore. It’s more like a bi-gloss.
TheTallGuy
Lincoln, NE
A diluted bleach solution on a rag would likely take care of it.
I have had a couple of my customers dye a faded old white car pink for a cherry foam brush. I thought it looked better but the guy was still upset.
So far the guy hasn't called me about it again so maybe it did come off, but I will try your suggestions if he does call. Thanks for all the information, crazy that's it's my first complaint after all these years.
Usually tri foam stains will fade when exposed to the sunlight a UV exposure.
