My Allen Bradley relay, on bay #2, is chattering to the point of throwing my breaker. Tech came out & changed my GinSan GS-27D, & that fixed it....for 12 days. Now doing the exact same thing again. Any advice...?
I am pretty sure on Ginsan units.... each bay is self contained. Except for the weep. It has been 2 years since I worked on one though! Some pictures are via the link below.... the bottom unit is the working unit.It's a little odd that only one does this. If it were a case of low voltage it should make them all do that.
The above from Stuart is right. Also Check the 24V coming to the Allen Bradley contactor. If it is putting out intermittent 24 V voltage then it can be the Ginsan 27 again. You can also replace the 24V transformer.you might check the wiring from the coinbox through the coinbox switching, back to the ER controls. may have a wire that is coming loose. maybe the switch for motor in coinbox is having problems. fwiw
Coinbox: meterboxWhen you say "coinbox", what exactly are you referring to? Also, what do you mean by "coinbox switching...ER controls " ?
Yes.... a coin box or meter box is where you put your money. Ginsan likes to use buttons.... but they sell meter boxes with switches instead of them. But your system may not be "pure" ginsan.... (another brand) it really does not matter either way. Everything works the same.... basically.Is the coinbox actually where you put your money, in the bays? Forgive my ignorance, as I just bought this, after coaching 24 yrs.
Buttons , & switch. Where are those? Where you put your quarters, in the bays?
Eric, good to see you helping people with pictures from my carwash.Yes.... a coin box or meter box is where you put your money. Ginsan likes to use buttons.... but they sell meter boxes with switches instead of them. But your system may not be "pure" ginsan.... (another brand) it really does not matter either way. Everything works the same.... basically.
http://cwguy.com/?p=7198
The GS-27D does actually do things.... Even though they are not necessary. The functions are basically….. if any LP function is ON no weep in that bay. Low water cuts off all bays and the best feature an one second delay for HP.we bypassed GS -27D, & it would fire up & work. Does that mean GS 27-D is bad? That's what I am thinking...
