wash4me
I have a boiler with primary secondary piping arrangement to my floor heat glycol system. I am considering adding plumbing and valves so that when I am not in floor heat season I could circulate glycol through the floor heat exchanger and "preheat" my water on the cold side of the hot water tank. It would have a flow switch in the cold line so that it only ran the glycol pump when water was being used. It would also have a thermostat setup that would only run the glycol pumps if there was at least 10 degrees or so difference in the glycol and incoming cold water temperature. Any thoughts?
