I use the Megs. microfiber system and have been very pleased with it. It cuts very well and the cutting pad and compound also finishes out very good. You can pretty much use the cutting pad and compound and go straight to your finish product of choice. Of course the Megs. system has the second polishing pad and polish that is also a sealant.
If using the Flex with the Megs. cutting micro pad it can be a little grabby but if you step down to the polishing pad it will smooth out. The polishing pad with the agressiveness of the Flex seems to work well. I prefer to just use it with the Porter Cable and get great results fast without any swirls, holograms, or problems that have to be corrected.
