Thanks, I will check to make sure it is bent at an angle that it will hit the top of both switches.There are 2 switches on the Payout switch assembly. The switch with the Red and Black wire controls the signal/power to the Coin Counter to make it move. You want to make sure the switch actuator is pushing the switch down enough to activate the switch.
