dbrown2911, STOP!!! Don’t move the wires around on the
coin switch!! If you put them on the wrong terminal you can damage the controller. If you have to replace the
coin switch don’t use the 11-0008 switch.
Hamilton has come out with an newer easier to install switch #100-0151, it’s a few dollars more, $42.70 list. Since your inside the Hopper look at the Hopper bowl. If it has a grove worn into the bottom of the Bowl it needs to be replaced.
