Has anyone been able to set up a goldline with crypto pay with leaving the 5.7 “ display?
I have never done a retro fit on a goldline but I see in the kit you have to change the display
To install Cryptopay your going have to remove the 5.7 display. Unfortunately Hamilton doesn't make a retro fit kit to plug the big hole and install a regular red display. What your going to have to do is fabricate a bracket to fill the hole and install the red display.
Port 15 on the Distribution Panel in the gold line is the display, plug the updated screen into the display plug like advised in the install, which goes back to port 15 and zip tie the screen behind the door somewhere.
Port 18 is the auxiliary display plug, plug the 5.7 screen into port 18, and the swiper needs power still (they say to plug into port 18 for power). I have plenty of extra cryptopay power adapters I can wire in to power the swiper.
Totally firing from the hip on this, give me your thoughts
After reading a Hamilton manual, I rescind my thesis. I had assumed the external display mirrored what the small display was reading, and it appears that is not the case.
