My trough system is made out of 4 inch pvc pipe. I connect them together with pvc fittings except in the bays where I use large electrical boxes. The pipe goes into the boxes and then I make all my hose connections in the electrical box with a latching lid. I use Raytheon heat cable called winter guard wet. The cable has extra insulation and I have used it in some locations for over 10 years with no problems. I do not even have to insulate the pvc pipe and the cable keeps everything thawed out. I see extreme cold temps for several months.
Twenty some years ago I bought a wash with that type setup. I found it to be difficult to access your lines when you needed to repair a leak. In some instances I would have to cut away the pvc pipe to get to the leak. I eventually replaced it all with a wood trough that had total access from the top. It was much easier for me to locate leaks, replace lines etc.
