Help with Fleck Softener Head not Counting
My Fleck setup did the same thing. Turns out that there's a "cap" that sits on top of the counter which contains a bunch of planetary gears. The gears wore out, and wouldn't turn the flexible metering cable. I replaced the cap with a new one, and I was up and running normally.
So after cleaning out the impeller it is now counting down like it should. Water is still hard. Found the brine valve on the good tank to be defective, so I'm replacing that and will then see where everything stands.
