I finally installed my JC super saver and I have some functions working, but have an issue with HP soap, wax and presoak. The issue I am having is that when I select wax, soap or presoak, the rinse solenoid is also turning on. Because of that, water is not being drawn from the hot water holding tank, and instead my hydrominder tanks for the selected function are getting filled with water. I have the system paired with the Ginsan push button doors and the decoder board. I have the motor starter dip switches set to on for those functions since the pump has to run, but the rinse solenoid is turning on as well and know that can't be right. Not sure if the issue is with the JC system or how the decoder board is communicating with it. Any help is greatly appreciated as I have been shut down for 5 days now and really need to get the wash back open. Thanks.
