Help with set up basics?
Stick,
There are probably over 100 different ways of doing the same thing at a CW...So giving you a possible road map that somehow match's your equipment is almost impossible! Are the pumps fed with city pressure hot and cold? City pressure cold - gravity fed hot water? Procon pumps for wax and PS or flojects or vacuum fed wax/soap??? Rotary bay switch or proprietary push button and control boards? Hydrominders, injectors, or Dosatrons? And the list goes on and on....You get my point? Like others have said, is there anyone close to you that could help that knows anything at all about a CW...Not to discourage you, anything is possible if you have the desire to research and not be afraid to implement what you learn...
Stick,
Stick, Do you know the answers to any of those questions? Once we know what kind of equipment you have, it will be a lot easier to help....
