SplishSplash
Self Serve Operator
I have two issues that I can not figure out:
Equipment is Coleman
First, spot free pressure to the holding tank is less than 1gpm. I replaced that membrane and I am stilling getting the same pressure. Bypass the filter and pressures are normal. I doubled checked to make sure the filter was not in backwards, now what???
Second, replaced procon pump on the tri-foam and still not working with a different problem! The motor starts making a clicking noise and runs intermediately, meaning it is clicking on and off. I replaced the motor with a spare, same problem. If I remove the hose going into solenoids everything runs fine. The solenoids are getting power and I can hear the air in the bays....
Thanks in advance!
Thanks in advance!
