High pressure soap hyrominder issue
tahoelane
Hello there,
I have a hydrominder issue, it is back flowing water into the mixing tank. To this point it doesn't overflow. It elevation in the tank is much higher than normal.
I actually swithed out the orfice after seeing water back flowing into the soap line. Something has changed and I can quite figure out how to get things back to normal. Any suggestions?
Lane in Sacramento
Dan kamsickas
GinSan Technician
Grand Rapids, MI
Put an 1/8" hole in the fill tube between the bottom of the eductor body of the hydrominder and the top of the liquid in your tank. You have a siphon problem
You might also have a foot valve issue. We stopped using the Blue foot valves that we used forever and have gone to a DEMA 110.11P no more problems
Ditto what Randy said. I switched a long time ago to the Dema valves he linked to and can't remember one failing! Scary!
