Hello All,
I have had a strange problem that has occurred several times over the last year that I can't figure out. I get to the wash in the morning, and several of the bays don't have any pressure, and maybe one is pulsating heavily, and a couple working properly. Then, after a few minutes, (sometimes I need to run the pump for like a full 4 minute cycle ) everything starts working normally. It always seems to happened in the early AM. Also, I have Mark VII pump stations which all the pumps get inlet water from a common manifold. I have narrowed it down in my mind to a couple possibilities. One is that I have an intermittant sticking air solenoid that stays open, and overnight when no one is washing, it pushes air back into that water supply manifold causing some type of air lock. My only other theory is the water softener is regenerating at some wierd time and somehow starving the pumps...
Has anyone else out there experienced something similar, or have any ideas on what it could be? Any advise would be greatly appreciated!
Sincerely,
John
Sincerely,
John
