I have a Hamilton SS-1 Changer that I'm taking out of service. It has been set up to dispense brass tokens, and still works like new.
I need a machine to convert $1 coins to 4 Quarters, and I'm toying with the idea of using this machine. Would it be possible to cut two slots (to the front door) and add a coin acceptor? Short or long drop? What brand?
I'm thinking that if I connect the pulse output from the coin acceptor to the $1 pin of the controller (C2000), things should work. Would the pulse be of sufficient timing/voltage to work? I'm thinking that if the acceptor "sees" a good $1 coin, the C2000 would interpret the same as a good $1 pulse from a validator.
Ideas?
Ideas?
