bigleo48
- Joined
- Sep 6, 2007
- Messages
- 1,887
- Reaction score
- 0
- Points
- 36
I?ve been toying with a windshield washer fluid dispenser for a while now and since I have a couple of extra selections on my coin box that are not used, I figured I would offer it in the SS bays directly.
It?s a simple setup, use a 55 gal plastic drum, a Hydrominder to mix from the concentrated WW fluid?a FlowJet pump and a hose bus across the top of the bays. Tap off to a solenoid (wired back to the bench) and to a curly hose and a gun in the bay. Some signage and you?re done! All equipment comes in at about $800 for 8 bays.
You then adjust either the pressure (FlowJet pump pressure) or restriction to the solenoid to adjust for the amount of volume you want to dispense based on your time/quarter charge. I figure here it would need to be $ 2 per gallon (yet to get good pricing on the winter WW concentrate mix). My problem here is that at 60 cents/min, it could take over two minutes per gallon to fill, people may think it?s not dispensing fast enough and that they are getting short changed. Really clear signange would help
I also like the fact that it would not need to weep up here in the cold north east!
Any suggestions on making it better? Do you think it would get used enough? Anybody gotta a line on bulk winter WW fluid?
BigLeo
BigLeo
