Creekviewautowash
I have an in line check valve for my foaming wax. Unfortunately it does not hold and I'm losing about 10 gal in chemical a night unless I turn the valve off.
The check valve that was on there was a VNR-1 made in Italy.
The rest of the information is as follows 450 bar, 45 f / min, 90 degrees C
I've already talked to two different vendors and they have both given me check valves but niether one worked. I seemed like the spring didn't have enough resistance.
The pump the line is attached to is a Flo-Jet rated at 20 to 90 psi.
I'm still learning so I could use all the help I can get.
Creekview auto wash
Creekview auto wash
