Information, opinions or reviews sought on RYKO PULSE
roller-up
sunshine state
Hello, I'm new to the forum- great resource!
Looking at the ryko pulse -
It will be used alongside our conveyor so it will be a low volume application- mostly for night time use when conveyor closes as well as for the touch free consumer
We are a stand alone car wash
Any info on the quality of the machine or ryko in general they're new to me
Thanks in advance
I just went through a brand new installation a couple of times with 2 different cars. It did not have the cleaning ability of the more expensive ryko touch less washes. It is sold as a low cost low volume touch less car wash. I run rumps and personally would not be interested in owning one of these. Just no sizzle so to speak.
roller-up
sunshine state
Do you think it could have been due to chemistry?
Or machine operation related -as in insufficient chemical coverage? Or insufficient pressure from the nozzles?
It coated the car fine with presoak and the triple foam was OK. It just did not have the impact that I am used to seeing with the high impact pump that uses more water at lower pressure. This pump was not a high volume type and just did not give water impact on the car that I am used to with a radius wash.
robert roman
Bob Roman
Clearwater, Florida
“….ryko pulse…used alongside our conveyor so it will be a low volume application- mostly for night time use when conveyor closes as well as for the touch free consumer”
Economic factors of in-bay automatic are price (capital) and expense (variable unit cost).
An expensive aspect of touch-less is high-pressure pump and bay equipment.
One way to lower price and expense is reduce pump horsepower.
Laser 4000 proved that single inverted-L is a very economical design.
Pulse fits this equation but is it the right solution for your problem?
For example, carwash developers usually invest when there is a good opportunity present.
Low volume, night time use and touch-less consumers (at conveyor site) do not sound like much of an opportunity.
For example, one my clients has conveyor with in-bay alongside. It’s a G-5 with all options. He prices the in-bay “very high” and makes “very good” money.
So you might want to reconsider strategy before spending several hundred thousand dollars for building and equipment to test the waters.
