Installation of In Bay Automatic
thecasino5
That's no problem at all. Happy to help.
The LXR is more less designed for the shorter bays. There is however some differences. Foam N' Flow is not an option and neither is the Power wheel Detailer but you can have Tri Color Foam, spectra Ray+, Big Shot, and chem alert. There is a few other small differences with the LXR but from a function standpoint it works just like the Profile Max does. The LXR in your size bay will wash crew cab trucks no problem and the height is 7'6" so the taller 3/4-1 ton pickups will work just fine.
thank you for the fast reply! I am not to familiar with the big shot and chem alert add on if you could please explain what they do... also without the power detailer will the lxr still somewhat clean the wheels with the side brushes? and just so i understand the LXR will clean as big of vehicles that the profile max will?
chevyguy09
WI
No problem. So Big Shot is a wheel cleaner that sprays chemical onto the wheels as the vehicle is going through the underbody. It can use 2 different chemicals with it. We have some video of it in operation on our website if you wanted to check it out. The brushes will also be making contact with the wheels. Chem alert is designed to let you know when you are running low on a certain chemical. There is sensors that would attach to your chemical tanks and when the chemical level would reach that sensor it would send you an alert. It is fully programmable as to what sensor you want to monitor for each product. This option works well if your not on site every day. And yes the LXR will clean the same size vehicles as the Profile Max.
thecasino5
Great thank you so much! have you noticed any significant differences in terms of wash quality from the LXR vs the Profile? If so how drastic would you say the difference of wash quality is? Also when pricing out my profile max I was quoted $20k for the touchless power wheel detailer is that correct? it just seems high to me... and yes please if you could drop your website link so I can check it out that would be awesome :)
chevyguy09
WI
Personally I have not seen a difference between the two as far as wash quality goes. I honestly do not know the pricing for the Power Wheel Detailer but judging by how the components are built and the amount of Stainless being used I could see it being in that range. Feel free to check out our website at www.washworldinc.com
