Clean Days
I recently purchased Nayax VPOS touch credit card reader. We had a simple swipe before with World Pay and decided to change them out for Nayax. The wiring I thought would be pretty easy since I had an existing CC reader but it doesn't seem to be the case. On the Nayax there are (2) 24v + wires, (2) 24v - wires and the green pulse. I connected the pulse (green wire) to the white/black strip wire off of my Dixmor timer and the (2) + and (2) - to the correct taps. When finished the Nayax will turn on and except CC's and its timer comes on but it doesn't energize my pumps or activate my Dixmor timer. The original CC swipe had one extra wire attached to it which went to my wire strip labeled "coin counter". If i touch that wire to the pulse the pumps turn on but they turn on without swiping the CC, it just comes on, so I left that wire unattached. Also, another possible issue may be that Nayax sent me a wire harness with a plug for the card reader on one end and (4) plugs on the other. I assume it was an MDA cable but I have no place for them to plug into, so I cut them off and found the (2) black, (2) red and the (1) green and those are the wires I used. My thought is maybe the plug that goes to my card reader is different on the MDA cable as compared to the cable I was supposed to get but I am not sure. Any advice on what I need to check or try would be appreciated.
