Now that you all have tested these "Jarvis" units for a few years, what are your thoughts? They still the best thing around for replacing Scottsdale 320W metal halides?? Any failures??
was told had a thread on replacing some old lights with LEDs. The link you have above, would those work for in bay wall mounted lights as well? Purchasing an old 4 bay with 2-3 wall mounted lighted and need an upgrade. Any info you have would be great!I have retrofitted about 8 of the 320 and I also tried one of these. https://www.ledlightingwholesaleinc.com/XBEAM-400-p/xbeam-400.htm These give a lot more light. They are made for Flush, not surface mount but there is an adapter available. The retrofits have been in place for several years. East to do and light is comparable to the 320 Scottsdale.
There is also a 600 W version available. It's great.
Surely it would state not to mount it to a wood or other combustible surface if it couldn't be.Anyone using a LED 2x2 ceiling mount fixture that can be attached to a wood surface? The roof at the wash I just bought is wood covered with vinyl siding. I've installed crees before at another wash built like this,, but at this project I'm going to have to deal with an inspector. Many canopy lights are not rated to be attached to a combustible surface. Jarvis makes some that are inexpensive but only put out 5300 lumens.
250W Equal LED Ceiling Mount Light 58W Canopy Light - CL-250-WHT
250W Equal LED Ceiling Mount Light - CL-250-WHT Jarvis Lighting Model Number: CL-250-WHT 58W LED Ceiling Mount Light The CL-250 is a superior parking garage and low bay canopy light. This light fixture is built in the US and is manufactured to ensure perfect performance throughout...www.jarvis-direct.com
I bought the X400 and needed to mount to a concrete surface which was an issue because it is not made for flush mount. The bottom protrudes upward. Found out make a collar / flange for this type of mounting. Perhaps that is how it can be mounted to combustible surface.The Jarvis X400 states in the instructions to not mount to a combustible surface.
