JC VACCUM/COMBO CARPET SHAMPOOER
kyros
Cyprus
Hi guys
i have an issue with a vaccum /shampooer.
When press the button to select the shampooer the display shows OUT OF ORDER. The machine has a manual key for vaccum and shampooer. When use the key the shampooer works fine.I change the display and val board for microcoin but nothing happen.
Any one can help?
thanks
Kyros
cantbreak80
Maybe I need new clubs
CO
Low level of product
Shampoo tank low level float switch
Poor connection LLFS to Timer
Faulty timer (8 pin harness - pin #6)
If the lower plug is flipped over it will do something like that too.
kyros
Cyprus
Hi
Thanks for your reply
The product level is ok as i can see it through the clear hose and also as i said it work manually.I also change the timer but nothing happen
There are two plugs on the timer, one is lower than the other, it can plug in upside down.
Is the replacement timer set properly to shampoo/vac? Do you have another shampoo/vac unit where you can test the timer?
Most likely your float switch is bad. You can manually jump the 2 wires to test. If it works fine with the wires jumped, then wait till it's empty, then replace the float switch.
kyros
Cyprus
yes the timer was set to shampoo/vac .today im going to check with my other shampooer
