Jim Coleman Meter Door Replacement
toddmullens
Are there any companies that can retrofit a new meter door to an existing Jim Coleman meter housing? I am wanting to add Hamilton credit card acceptance without having to replace the entire meter box or having to add the separate DTT box. I would like to have it all inside the original meter housing if at all possible. I probably will end up having to replace the entire meter housing, but I am trying to prevent that if possible. The current meter door and housing dimensions are 11-3/4” wide, 17-3/4” tall and 5-5/8” deep. Any recommendations?
I had the same exact door and swapped them with a retrofit door from Ginsan. Talk to Doug Empie, he is a great guy and can hook you up. They can design it as you wish while keeping with the specs of the old door.
Sweet! Do you have any pictures of your door that they designed?
I would think you could put a cryptopay swiper on the left or right side of the side of the box next to the display window or coin slot. Did this with Vacuums but made a "Standoff from 2 1/4" pieces of lexan the size of the cryptopay swiper and pu those at the base and used longer screws to affix - That way customers could swipe and card would not hit the bottom lip.
