Kip solenoid question.
1carwash1
east japip
Does anybody know the dimensions of the individual stainless Kip solenoids that KR sells? I’m trying to configure a custom manifold and need that height. Also, do the individual Kip solenoids have a dedicated input/output port. Can the coil be rotated around the solenoid shaft?
It's 2 5/16" tall, the base is 1 1/8" wide. Yes, the in/out are dedicated, but you can use them in reverse if there's no pressure like the soap/wax supply to the pump. I run them reversed there so I don't need a check valve to keep city pressure rinse from backing up through them. The coil can be turned freely.
