Kleen Grean
MC3033
Midwest
Yep. Compared to regular oil it runs a bit hot and needs to get changed more often
compared to other “non oil” hydraulic fluids it is comparable
DavidM
PA
We tried it (more than 5 years ago) and had a rash of hydraulic hose failures. Maybe completely unrelated, maybe just a compatibility issue with the hoses we use, I don't know but we stopped using it.
We use Aquablue, expensive but when we returned to Aquablue the hose failures went back to a normal rate.
David
Most hydraulic hoses are designed to have oil go through them. Water going through invites rust with the wire re enforcement and then ruptures.
MGSMN
USA
Ron, are the SELFIT fittings reusable?
Back4More
Equipment & Chem Supplier
Malden, MA
No, they are made for 100R7 hydraulic hose and once they go on they are permanent.
Ron
