Who's fault would that be?
UPS. Assuming KR put in the request, they would have to actually follow the instructions, but in my experience they rarely do.
Correct is a pretty hot product. How is it cleaning? Instead of a booster have you tried going up to the next larger Tip size or two. We use Super Kleen powder #KRSK10 and it cleans very well. We use a Red tip for soap injected into .083 dual injector with a tan tip for foamer. It uses about .75 ounces per car of foamer. Absolutely paints the car white....very impressive!I am using correct powder and would like to add a booster to it to help make it stronger. Is anybody using a booster with there correct powder if so what is it and what results have you had?
I am using it on my 4000 with a brown tip and the titration came out at six and the soap guy said he likes to see the HI soap titration be between 15 and 20.
With the KR powders you should see a cost per car on a IBA below .40 cents with a double pass even with boosters. I was over $1 per car when I switched 10 years ago from other presoaks. I never get complaints about the cars not being clean. Correct works great through a single tip injector and I use a double tip injector with Super Kleen and a surfactant/booster mix.
On my 4000 I mix the correct with the third of a 5 gallon pail of purple passion yellow tip.
Sometimes I don't use the purple passion and I use the simnz foam.
Titrate said about 18
Plenty of show uses about 10 oz
If it's top washer gets two passes second pass uses of blue tip at about 8 oz
You got to let it sit though mine's 15 seconds
Do you add the purple passion to boost the strength of the mix or is it just for show? When using the purple passion does it turn the product color for a better show? Does it add a smell to the wash pass?
I have 2 of my original Ryko SS pump benches that use flow meters for soap and HP wax. I have been using the setup for over 25 years with very few problems. FLow meters are nice since you can change your product concentration just by turning a knob.
