Laser 4000 rollors black/white thin wide?
Mansfield ohio
Hello,
need help on what rollor to put where please
i see there are black and white and some are derlin some are regular some are wide some are slim ?
Thanks
ps does the virtual treadle upgrade come with the buzzer? Or is it add on
thanks again
PEI
Danville, VA
The black rollers go on the passenger side and the white rollers go on the drivers side. They should all be the same size.
Mansfield ohio
what about the trolly?
aslo i assume the derlin is just a stronger material
because theres two to choose from standard and derlin
thanks
PEI
Danville, VA
The black rollers go on the entrance side of the trolley and the white on the exit side.
The buzzer should come with the Virtual Treadle Kit.
MDrost1
Grand Haven, MI
White have tighter tolerance to the rail and acts as a guide to the bridge/trolley, I believe. Black functions just as a roller.
washnvac
Seaford, DE
At a location I bought with 2 lasers, they are black all the way around. And I just ordered all black for replacements. The ones on have been there 4 years plus.
AlBuko
Green Bay, WI
The black rollers are usually the tight ones, the white are loose. You want the black rollers to be on the same side as the proximity switches. The purpose of that is to maintain the proper air gap with the flags. The white rollers allow for any expansion or contraction of the rails.
PEI
Danville, VA
You know I hadn't ever noticed, but our bridges that originally had a treadle plate all have the black rollers on the entrance side and white on the exit, while our bridges that originally where Virtual Treadles have the white on the entrance and black on the exit. I have always just replaced the rollers however they where on before.
Mansfield ohio
Mine have grease going to them can i eliminate with a differnt roller and bearing
my wash world guy showed me some that didnt need grease?>
thanks
