I've had to replace hydrolic oil in my motor just about every day. Can't seem to find the leak anywhere. Usually when a hose gets a hole in it, the wraps get oil all over them and it's a pain to get off, but now I can't see oil anywhere. Any tips on finding this leak?
If you can, turn off all the water spraying on your equipment and dry off your hydraulic motors and run them for 15-20 min. If it's leaking it should start seeping by then. Red dye helps too as wash103 said.
