LED6 or LED6s for multi function vacs
What is the best timer to use on a Jim Coleman combo ( 3 fragrance/vacuum)? Is it LED6 or LED6s, or is there something cheaper but as good?
I think the led6 is if you want a different price for your vac vs fragrance. The led6 can only have one price. As far as it fitting or mounting I'm not familiar with your vac.
You have to use the LED6S to replace the timer on a Coleman fragrance/vac or shampoo/vac. There's a Coleman retrofit bracket you'll also need.
It's cheaper to repair the old timer, but the Dixmor will be a lot more reliable.
Do I have to go through Coleman to get the retro fit bracket?
Kleen Rite sells both the bracket and timer if you need them. You can buy either or both. LED6s is way more reliable and has a nicer screen. I stopped repairing the Colemans and using the 6s when the Colemans go bad.
pgrzes
S.E. Pa.
Yeah modify the Coleman bracket thats there! Hammer out the two sides that are bent into the bracket and I believe you just flip it over. You can either zip tie the timer in or use good 3m double sided trim tape or both.
