Has anyone used a good quality needle valve that isn't ridiculously expensive? I used to use the Rego 1/4" but not buying them in bulk means they're over $30 each. I'm looking for one that's under $10 and accurate and doesn't drift.
Whats wrong with the ones on KR's site? I use the 1/4" x 1/4" ones on my weep system and haven't had to touch them once they are set..They don't break the bank....
The cheap ones are horrible, they look as bad as they perform. No accuracy in the adjustment - I like being able to open all the valves 1/2 turn and get the exact same flow from all of them. Even the $20 one isn't that accurate and that's more than I want to spend.
I found a valve like that from KMFit which also has inline versions that would mount better on a panel that I'll probably test as well as the one you linked.
