stampedecarwash
Hi guys,
One of our pump looses pressure when it goes on hot functions like high pressure soap and wax. These functions water come from hot water tank and its only gravity, no pressure behind it like it is when you go on cold Rinse. Please see the video. My first thought was the check valve under hot water tank is not opening completely so changed it to new one. See pic. Then thought maybe the ball valve is not opening but opened it and it opens completely. I did open the head and saw washed out areas but still decided to change the seals and that helped ( probably temporarily) with getting back to 1200psi on rinse but when it goes to soap/wax it looses pressure asif the pump is being chocked. My next move is changing the head now but thought ask and see if you have had similar experiences. Thanks
My dilemma is if the head is bad, why cold Rinse function is good.
