Loss of pressure on cat pump
Kool Wash
usa
I'm having some loss of pressure on a brand new cat 5cp pump. Put on a new high pressure regulator thinking that was the issue, checked seals and valves. When the gun is not depressed, pressure is 1400, as soon as you engage trigger you can feel pressure discharge and the psi falls to 800. I cannot get it higher than 800 with trigger pulled. Thoughts and advise? Appreciate any feedback.
check the nozzle in the bay, if it is old and work it can cause a loss of pressure when the trigger is squeezed.
Other than a very worn tip, is it possible there is an obstruction of water flow to the pump?
ken-pro
Equipment Distributor
Kitchener, Ontario
Very likely a faulty weep check valve. A failed weep check valve will leak some water back to the water supply, causing a drop in pressure.
If this is the case, when the bay with low pressure is running, the others will weep water.
Kool Wash
usa
I changed the tip and the belt, still no dice. I will check the weep valve and hope it's that as I don't want to start the eliminating process. I'll report when I find this and as always thanks to all who chipped in.
