You can plug the dump valve with no affect on the wash unless it is more than two bays away from the equipment room. The further away from the equipment room, the more time you will need to give the low pressure delay and high pressure delay to make up for the lack of dump valve. You can also just live with the arch not having changed over chemicals or rinses when it first starts across the front of the vehicle and not worry about the two delay timers.
