LW 4000 Forward/Reverse (variable frequency drive)
My used LW is being installed. Few days ago it moves F/R, no problem. Electric company puts in a new pole & now I'm getting 1 1 showing on ABB frequency drive, where as before I got 0 0 (when it worked).
Any advice? you can tell me here or call/text 409-200-4667
coach
BBE
USA
Try putting a meter across the 3 legs coming into the vfd. If you look at the bottom of it there will be 3 wires labeled "main" These are your 3 legs coming in. Test the voltage across them and make sure you are getting the correct voltage, and there are no dips/spikes.
BBE, that's the 2nd thing we tried. Good advice. Still bewildered though
