Mac valve Leaking Air
DivineSuccess
Pittsburgh
I have mac valves running some doors in my tunnel and they have been leaking a good amount of air through the exhaust valves. I took them apart and cleaned the plunger and surrounding parts but to no avail. Anyone have some how-to's to cleaning these out?
TIA
John
MikeV
Houston, TX
Mac valves are generally not repairable, at least not to any reliability. Just replace it and save yourself some grief.
washnvac
Seaford, DE
I had this issue quit often on an iba that has two mounted on the machine. I finally installed a solenoid on the air line that shuts the air off when the wash is not in use. I have not bought a valve since; has saved me a good bit of money.
Dean Taylor
Dean Taylor, CATEC.com
Sarasota, Florida
Be sure you have a good moisture separator on your compressed air line too. Moisture will take out MAC valves if exposed over time.
