Measurement eye not on at start of wash
TunnelGuys
Gadsden,AL
You may want to check the junction box normally located at the floor below the Red Lion control panel (the conduit line where the eyes travel from the bay). Check to be sure those connections are not corroded. If you have enough slack in the cable then cut it off and solder the wires then put on a wire nut
WizardManiac
TEXAS
WELL MY PROBLEM APPEARED AGAIN TODAY.....:confused:
I have already replaced the receiver and the transmitter. This is the first i have ever heard of a built in delay for the eyes? As i understand it there is a just a relay in the water wizard panel that cycles the power to all eyes at start of wash just to make sure they come back on and its to check functionality of all the eyes.
Check for floating wires from receiver AND Trasnmitters conect them to 24vdc+ except black wire from Transmitters...Good Luck.
Alsoar
Sydney, Australia
I ran into the same measurement eye alarm as well so i thought it would be better to use an existing thread than create a new one.
I tried looking through the owner's manual but i couldn't find the answer, so my apologies for being a newbie.There are two diagonal beams on the WW2, one in the middle on the gantry and the other in at the end. Can someone kindly point out to me which is the measurement eye and what is the other one?
Thank you.
Tom Thumb
Orlando,Fl
Can not answer for the ww2 but on the ww1, the eyes in the cans on outside are the safety eyes and the one inside the gantry are the mearsuring eyes.
