Medeco Lock Stuck !
340wash
I have a Medeco plug lock on a Hamilton changer that decided it was not going to work any more. I have seen previous posts about lock removal. If anyone can help I would certainly appreciate it. The key easily goes in and out but will not turn. It worked perfectly three days ago. Email or PM me. Thanks ! 340wash
Before doing anything drastic, take a hammer and tap on the face a few times with moderate force (remove the key first). Then try the key again.
All of the above, but I would also saturate it with WD-40. Sometimes a small particle (dirt) can get in behind the little bar that does the locking. We are told not to use WD-40 on locks, but we hit all of our locks with WD-40 occasionally which does smooth things out when inserting a key!
I just had this happen 2 days ago.
I thought someone had taken my Medeco out and put their own in.
I only had 3in1 oil with me.
I put the oil on the key and kept working it in and out.
It finally let me open the lock.
David
Had this happen twice in the past. It always worked after tapping the lock a few times with a metal object. Don't give up - keep on tapping. Good luck.
I spoke with 340wash today and he’s done everything you could possibly do to get the plug lock out. WD-40, Oil, Tapping the lock and the surrounding area with a hammer etc. His last resort is to drill the plug lock. I sent him instructions on how to do that.
I've had this problem, also. Heat and PB Blaster seems to do the trick near term. Replace them as soon as you get them out. Seems to be yet another example of lower raw material standards and less durability.
