medeco plug lock, ugly!
jack954
this is what i came into this morning. thief spent an unsuccessful hour trying to get into it, then i spent an unsuccessful 2 hours trying to finish it. what’s best bits to use-cobalt, titanium?
I see it was amateur day today! I sent you a PM telling you how to get it out.
  • Like
Reactions: APW
FWIW This is why I had a circular collar that fits around a hockey puck lock and a Metal Square with a rectangle tab and hole in it welded to the door. Hopefully they will get tired by the time they get done with the Hockey puck. If I do it over i would likely have the welding shop do the same metal tab but a separate cover like they have on some vaults - for the hockey puck lock.
AnalyticWash
Do you have a picture of this?
This says "Also available for change machines" and looks like it just mounts flush on the changer, so it might fit on the safe head. It would install in a few minutes with no special tools.
If you do have a tab welded on, use a good lock like CobraLock. The American 2000 pucks can be melted off in a few minutes and opened with a comb almost as easily as with the key.
the last time i had a drill- out attempt on a medeco plug lock it was so half-a$$ed an attempt that i was still able to use the key to remove it!
I've never that lucky. The idiots normally break the drill bit off inside the lock.
WashOwner
I've had the same issue, but on the Medeco Cam locks on my JE Adams Shampoo vac. He tried both locks but didn't get in. Can someone PM instructions on how to drill out or remove the cam locks? I have replacements.
Can you show any proof that you own a car wash? I hope you can understand how your first post here seems fishy.
WashOwner
Understood, and I appreciate the caution, this forum shouldn't be a university for carwash crooks. Here's a photo of the damage. I got replacement camlocks from Kleen-Rite but I'm looking for suggestions on how to get the damaged ones out without causing more damage to the faceplate or internals. Thanks for the help!
Nice picture. It doesn't tell me much. I just sent you a PM asking for the location of your car wash
