Will the Microcoin QL insert (actual acceptor) fit into any other mounting faceplate? The JE Adams website shows a Microcoin QL mounted in an all stainless faceplate. The faceplate they use for this seems to be similar to the IDX faceplate.
I tried putting in just the insert into an IDX frame (IIRC) and it looked like a drop in but is too fat. The frame would have to be cut out for the QL insert to fit.
The QL bracket was redesigned many years ago.
It features locating holes for the acceptor's pins and the retaining strap slides down and snaps in place. No tools required.
It actually will fit into the IDX frame but you have to unscrew the screw that holds the bottom of the frame together, and slightly bend it down. It’s a much better frame than the plastic junk that the Microcoin acceptor comes with.
