Dixmor timers only:
Connect black wire to 24 VAC.
Connect yellow and a blue or green wire to Neutral.
Connect the other blue or green wire to timer coin pulse.
Blue and green are the relay wires, hooking both to same pin won't do anything. Your original wiring should have been correct according to microcoin instructions I posted above. You can try blue with the black and green on #2
I can check my wiring tomorrow, but pretty sure I just used the microcoin directions and it worked. Black to pin 10, blue and yellow to pin 9, and green to pin 2
Help me out here guys. I’ve got black hooked up to 24vac. Blue and Yellow to common. Green is tied to the pin 2 on the led 6 (coin pulse).
The light in the unit is green. I can hear it register the coins but it’s not registering with my timer.
