Mortons Clean and Protect Softener Salt
Yep - at one extreme, I've seen a brine tank, with the cap off the brine well, filled to the very top. Softener wasn't working... go figure.
And many times I've seen little to no salt at all in the brine tank. Softener doesn't work in this situation either.
We've seen salt bridging as well - typically when the user thinks if a little salt above the water level is good, a LOT of salt above the water level must be better.
FWIW I've never had an issue with bridging, and I always fill the brine tank as full as I can.
To follow up with this thread, I recieved an email and phone response to my inquiry. Here is the email version which reflects about the same information as I got with the phone conversation:
Thank you for contacting Morton Salt. We are sorry to hear you were dissatisfied with the Morton® Clean and Protect™ Water Softener Pellets product you purchased.
Our products are produced across many of our manufacturing locations and processes. Each of our processes are slightly different in how they manufacture our products, which causes a slight variation in color and size of the pellets. However, all products are tested to ensure that they meet our specifications prior to shipment. These visual differences will not impact the functionality of the pellets or negatively impact the water conditioning systems.
Will you please be so kind as to provide us with the following information so we may continue to log your feedback:
• the LOT number (near or on the seam on the bottom of the bag that will start with the number 5 and contain 8 digits)
• a picture of the salt
Should you have additional questions or comments, feel free to contact us via our toll-free number (800) 725-8847, Monday through Friday 8:30 a.m. - 4:30 p.m. CST, or via our website at www.mortonsalt.com. Again, thank you for contacting Morton Salt.
At this point, I'm uncertain as to what to do. After clearing the small amount of scum off the top of the brine tank, the water seems to be pretty clear. I'll keep my eye on it and see how it acts over time.
Mep, I'm sure your comment works for you on filling the brine tank to the top with salt. But for me, it doesn't work. In the beginning, I kept the salt filled to the top and since I use a little amount of salt, the salt turned to mush and kept it from working correctly. It took me a while to figure out what was wrong with it. Plus you can never see directly how much water is in the brine tank after it refills. The water supplied to my wash is already softened to 5 grains and I soften to zero grains. So my softener only regins ever 9-10,000 gallons. Sometimes only 1-2 times a month. So the salt can sit in the brine tank for a long period of time. I can see if you have really hard water and your usage dictates multiple regins a day, then filling the brine tank to the top makes sense. So a blanket statement to keep the tank full of salt might not work for everyone. In my case, it doesn't work or make sense. I keep the salt higher on one side so the salt is out of the water and I can still see how much water is in the tank. The pellets disolve properly given my usage. It works better like this for me....
Yeah, I've serviced softeners that hadn't worked in months or years, and the salt does tend to break down. Most that I deal with will use 15 bags of salt a month, so they're regenerating almost once a day.
For now I decided to switch to Diamond Crystal Pellets...I picked up 10 bags from our local Tractor Supply Company for $4.99 a bag. It is snow white like the Mortons used to be...I can't see risking issues with the softener just because a Mortons rep said it "Shouldn't" cause any issues! Plus, at $4.99 a bag, its a little bit of a cost savings.
Snatch it up while you can. Tractor Supply's price on line for Diamond Chrystal is $5.99 / bag, or $5.69 if you buy 20+ bags.
Home Depot has it for $4.92/bag @ 6+ bags.
Rural King is $4.99/bag for Diamond Crystal. IIRC it was only $2.99/bag when we bought our wash in 2017.
So whats everyone buying now a days as the dirty #44lb salt from sams club is still showing similar issues in 2026. Noticed this since 2024 and saw this post so curious if switching to Home Depot Solar Naturals Water Softener Salt Crystals is better?
Just trying Home Depot since they offer delivery if i purchase a pallet.
Just did some price checking here in Cincinnati for Morton Pellets.
Sams @ 44 lbs = $6.98 ($0.15 per lb)
Home Depot @ 40 lbs = $7.45 if buy 10+ ($0.19/lb.)
Lowes = My store no longer carries Mortons
Tractor Supply = My store no longer carries Mortons
I wonder if Sams is buying a lower grade product?
We have always used Diamond Crystals brand. Never got a bad batch and because of that have no reason to switch. We buy a pallet at a time at our local fleet farm. Our water that we use is fresh great lakes water so I am sure that helps a bit as well. $6.79 for 40lb bag
