Nayax AT-400 flat pak timers
lighthousecarwash
Has anyone added Nayax readers in count down mode to their vacs using only the AT-400 flat pak timers? I would like to add cards to the vacs, but don't want to redo face plates and add LED7 timers just to make it work. I know voltage to the Nayax will have to be taken care of with a transformer or something, but does the Nayax just send pulses to the timer like I clicked the coin switch 4 times?
Thanks,
Lighthouse
UtahYoutubeGuy
Your Nayax device could also be a timer itself. You would just get a relay to send power to the vac when your nayax flips it on. In this case your nayax device would display the time remaining to the customer.
lighthousecarwash
So this is an interesting concept. If you paid with quarters, would it be able to show the time?
Thanks,
Lighthouse
Keno
As far as I know nayax doesn't take external payments pulses to activate the timer
