Nayax value should be factory pre-set to Quarters. [$.25] and Minimum charge amount.
Contact
Nayax to confirm
With Dixmor LED6 timers:
Program “
Coin Valu” [$.25]
Program “C” Time per
coin/pulse to desired seconds per
coin
Program “S” Number of
coins/pulses to start to desired value
Program CC Pulse Value to [$.25]
Program “Dollars on Count Up” to display dollar amount charged as it accumulates
Connect
Nayax Pulse 1 wire to Dixmor LED6 White/Black wire (Pin #8)
So…
If your start up price is $3.00 (12 quarters)
For 3 minutes (180 seconds)
180 seconds / 12 quarters =15
Dixmor “C” menu setting will be [15]
Dixmor “S” menu setting will be [12]
A
credit card customer will see the timer scroll money spent as it accumulates…just like a gasoline dispenser.
Does the #8 pin wire needs to be connected to any other wire other than the pulse 1 wire?Having a hard time with this! Thank you !
